vcSetBaseStatement
A statement to update the position of a base frame.
Module: vcRobotics2
| Base | vcKinematicFrame | RW | Get or sets the target vcKinematicFrame. |
| IsRelative | Boolean | RW | Get or sets if the base position change is relative to its current position. If True, the Position property's value is added to the current position of the base. |
| Position | vcMatrixExpressionProperty | R | Gets the matrix expression defining the base frame's position relative to its parent. The given transformation can be also relative to the current position, see IsRelative property. |
